beater_k20
Banned
CyberSniper said:You must've used a lot of nitrous in that sandbox built plastigage motor you're so proud of, eh?
actually, the one engine with cast pistons i played with on n2o, ended up with a trio of 5.7s through the water jackets. the pistons let go, leaving the business end of the rods and the wrist pins alone with the bare cylinder bore. amazingly enough, none came through the oil pan, and nothing ever came off of the crank.
i havent used plastigage since i was a teenager. that's why i own a high quality set of micrometers, and a dial bore guage.
If your going to ask for an opinion at least listen for freaks sake!!!
