BlaZeus
The Real Mateo
Hey y'all, put my fuel cell back in, hooked up the fuel lines, and then saw my fuel filter was pretty dirty so I took it out and cleaned it and put it back in. After doing all this, I am not getting any fuel to my carb, or my fuel filter. I took out the fuel filter again and saw the "in" end had some crap in it so i cleaned it out but still not getting any fuel. I still have a mechanical fuel pump. Do these get clogged and prevent fuel from getting pumped? It worked fine before I took out the fuel lines to do my rear 4 link. Any help is greatly appreciated! Am I just gonna have to nut up and remove all the fuel lines and manually flush them out to see if there are any blockages? or is my mechanical pump jacked and I should just get an electric fuel pump? Thanks! I know its something in the fuel lines because I sprayed Carb cleaner in it while turning over and it caught and started for a second. also, obviously not getting any fuel in the carb.
