buckmtn
Should have gotten Alloy USA shafts. Went to install my longfield joints in them and could not get them together enough for couple of snap rings to seat in groove properly. Could have pressed them back out and ground just a little on the inside of the shaft for cleareance but did not want to risk damage to joint taking in and out. To expensive to risk busting the end of one of those caps out. Just put a small tack on the cap to make sure it didnt come out. After all that went to put in the axle and the stupid ears on the shaft are to big to slide through the knuckle. Randys R&P says that sometimes they need to be cleareanced some.
Thats bull... If that is the case why did only three shafts need to be clearanced and the long side shaft slid right in. Sounds to me like they need a better QC department. For the money they should be right on!!!! Sorry for the long post anyone else experience this. Hopefully my joints will be OK
