What would you do with a budget 454 build?
Basically I have a stock 88 big block with peanut port heads and 8:1 compression
I really don't have much money to spend on it either.
It looks like I'll need some new pistons to get the compression up.
But after adding up the costs of redoing all my stock stuff it seems like I might as well go with a 496 rotating assembly
This kit for 1k seems to include everything I need, then to machine the rods and new bolts will be around another 150 dollars. I'll also have to get new heads then too.
http://www.usaperform.com/chevy-engine-rods-cast-crank-flat-pistons-bearings-p-421.html
