So when I get a new torque converter I put it in the transmission first and then when the transmission is bolted to the engine I I still have room underneath the put the bolts in and tighten them?
flywheel wrench for grabin teeth and turning motor easy![]()
I think the engine will be easy compared to this![]()
Pretty sure u would have had much less problems had you taken the torque converter bolts off first...
I didn't know to do that first...do you think I ruined anything because of doing it that way?![]()
I'm still sitting here in disbelief that I actually did that today...![]()
I bet its fine man (unless ur gettin a new one i cant recall)
ITS A PRETTY COOL FEELING THOUGH ISNT IT!!!!
I was so stoked the first time i took mine out of my bII, then the 2nd time I got it out in like 2 hours compared to all day lol.
Yeah...but I am dreading the reinstall even more....this part was hard but it was like downhill...going back on is going to be uphilll....
"I was more concerned that maybe I could have bent the spline shaft that comes out of the transmission or maybe even the flexplate...
