K5dreamer
hmmmm, ive no particular love for a CV over a joint
good information to have. thanks for all the pointers.
good information to have. thanks for all the pointers.Like gmc4cw said, you can re-drill the case. If you look on the LOMAX round pattern 205 case, there are two sets of hole drilled for stock position, and 2" up rotation.
You can cable shift it pretty easilyyeah, that would be the cheapest route, but maybe not worth it with a $70 plate. You're still left with a shifter issue though.
If you want the case flat, I beleive you need to clock it 4 inches. Mine is clocked 3 inches and its nearly flat, another inch would probably do it.bringin this one back from the dead. Anyone thats redrilled there 205 case out there? did you have a template? How do I know how many degrees of rotation to have the case lay flat? Help...
What I wanna do is redrill mine like a Lowmax case so when I swap in a lowmax case I dont have to redo my skid/crossmember
