np205 idler shaft removal, shaft turns with nut?
14-Bolt
Oregon
There is no extrusion in the shaft where it woul line up with hexcase to keepit from spinning. How do i get this thing out of here. Can i push it through, hitting it from the 3 bolt cover side? Thanks guys
So i have to pinch the shaft between both ends in a press. Are all idler shafts removed this way or do some have a wedge at the 3 bolt cover end that stops it from turning? Thanks man, just the info i couldn't find elsewhere.
Usually a 1/2" impact gun spins them on and off with no problems. All NP205 idlers are the same, round on the ends.
