77crewcab
Should have said my intent is purely for towing.
gauder said:I thought that the GEN I style smallblock built until 99 still had the standard sb/bb transmission bolt pattern. I know the LSX motors have a different bolt pattern. Could you show an example? Not arguing, just unaware of what year they did this.
ramses said:Well this got a little technical lol. So what years and types of trucks can these transmissions be found in? Would it be possible to put one in my 73 K20? It has a 350,sm465, and Np205. The only reason it interests me much is the higher gear that I would love to have for the interstate.
sandawgk5 said:There is. You bolt a ranger gear splitter in front of the 465 gear box. They have 2 different ratios I think. The lower ratio gives you about .78:1 overdrive while in 4th. Do a google search for Ranger Gear splitter and there website will come up I dont know the cost but I do know somebody on here has one on a K3500 in the for sale forum.
Ira
snoman87 said:To use your existing t-case you need to buy and adapter or get yourself a 86+ 205. It has a 32 spline and should bolt up to the back of a NV4500 without modification ... it's even clockable![]()
K5MONSTERCHEV said:Why do you want to use a 203?
DEMON44 said:I lost the 5th gear nut on my NV4500 3 days ago, behind my CTD.
It is NOT a catastrophic failure, in fact it doesn't do anything except the loss of use of 5th. The nut backs off, the gear slpis off the splines and just freewheels on the shaft.
My '98 Dodge is in this current state. I'm deciding on which way I want to fix it.............and no the CTD is not stock.
