I have a 99 Jeep grand cherokee that I'm trying to get the caster into spec. I'm at 4.3 degrees and I should be at 6.75.
The fix is to use offset ball joints. But, there are both upper, and lower offset joints and I dont know if I need one, the other, or a combination of both. Just thinking about the geometry of it, it seems like there would be binding if replacing only one with an offset one.
Does anyone have any knowledge about offset ball joints and using them properly?
