GalDemSuga
Can anyone tell me which line is the return line at the oil filter/block and at the oil cooler itselt. I may have mine mixed up.
does it matter? On my style cooler, both inlet/outlet are on the bottom anyways.
Are you replacing lines? I need to get a new line, but the new parts on rock auto are described as upper and lower. Mine go into the filter sandwich plate next to each other, and both enter the bottom of the cooler. So who knows?
This is a pic I took of mine before took the hoses off to clean up, so I would put them back in the right place. Iwill have to look to see the fittings are different sizes. Just know one is braided and one is rubber. This is a factory GM oil cooler.
Hm, not the factory cooler i have. The factory cooler i have has 1/2" NPT fittings that go strait into the bottom, vertically.
1986 model, come as part of the trailer package.
Hm, ok. I think they changed for 89-91, as 4x4high has the same one as me.
Those part #s I gave are what you need for your truck. Its the same as my 1989.
Awesome. Got it.
. Thanks a Million.On a side note, its snowing here in Snow Shoe, PA and I'm sure glad to have automatic locking hubs. Thanks a Million.
