I was feeling so proud I thought perhaps I might look into inspection... because.. you know.. it's expired
Well... I didn't know emissions was required on a 76. And a beam indicator??? Are you SERIOUS?? I don't even think that's an option on the instrument panel...
Who told you had to smog it. I know my 77 would not pass. In Texas if vehicle is 24 years or older its smog except. You should have a beam indicator if you have to have it should be just a bulb behind the dash. Any hood from 73-79 will work.
Item 11 on that list means the vehice has to have the emmisions equipment that was on it when it left the factory. On yours theres none so your good. Go out tonite and turn on your headlights and cycle the dimmer switch. See if the two little blue lights on top of your speedometer come on and off.
As directed, I cycled the dimmer switch- FAIL. I guess it's a good thing because something is broken. The headlights work, but if I click that switch they're gone. I have no idea if I'm running brights or regular lights- it's a 76 .. the brights are probably dimmer than my regular jeep lights Frankly, I don't need that to work but I wonder if it was always broken and I didn't know it or what...
Also, I've been looking for info on this but haven't really been able to find what I need:
A while back I lost my speedo and the (ugly) aftermarket tach. Still get lights to both but neither work. Most other gauges on instrument cluster are fine, except the volt meter, which has never worked per P.O. I'm going to keep digging- the searches I did here give me mostly answers with transmissions in the title and that makes it tough for me, and the manual is NO HELP. It's a manual transmission. If anyone can school me as to how the speedo works and how to get it back.... not that I really need THAT either... I figure if everyone around me is going the same speed then I'm ok...
Also on the books for today is to pull the carpets. I hate them.
Has anyone done drain plugs? It's a huge design flaw IMO for a vehicle that can go topless not to have them....
It'll will be loud and annoying in there with no carpet. The speedo uses a cable to drive it. Is the cable even there? It may have been bad (whined), and a previous owner may have disconnected or even removed it.
Speedo used to work. So did the tach. the tach has 4 wires coming off of it.... Pic attached. Able to trace red white and black but the green one just goes thru the firewall to nothing. Maybe it got unplugged during previous woes??? Where does it go??
Also if you were curious about where the other wires form your tach are supposed to go, the red wire is 12 volts keyed, the black is ground, and the white taps into your dash lights so that the tach lights will dim with your other lights.
