OK i think i figured out the DEATH WOBBLE.
[ QUOTE ]
OK , I have to ask , what is " bumpsteer"
I probabley know , but have not heard it called that /forums/images/graemlins/blush.gif
[/ QUOTE ]
In the case of an independent front suspension, Bumpsteer is a change in Toe of your front tires as your suspension travels up or down, without the steering wheel moving. If you think about it, the tie rods travel in an arch around a radius, the center point being the inner tie rod end. Picture a point in the suspension travel where the tie rod is level, this is where the distance from the center of the vehicle to the outer tie rod end is the greatest. Now picture the suspension at full droop, where the tie rod is angled down towards the outer tie rod end. At this point the distance from the center of the vehicle to the outer tie rod end is shorter and the tire will either tow-in or out, depending on whether it has front or rear steer, causing the vehicle to steer in that direction without any steering wheel movement.
In our Blazers it’s a little different because it is the Adjustable Connecting Rod that connects the Pitman Arm (arm off the steering box) to the Steering Arm that travels around a radius between the Pitman Arm and the Steering Arm as the suspension cycles up and down, causing the steering arm to move back and forth as the distance shrinks and grows.
Check out Bumpsteer for a good explanation.
Regarding “Death Wobbles” if all ball joints, tie rod ends and other suspension components are in good shape, the most common cause is being out of toe, but another culprit could be Caster which is not really “adjustable” on our trucks as it is built in to the axle, spring perches and springs. Your caster could be off (not enough caster) due to old springs or after market lift springs that are not correctly built.
P.s. Your Sway Bar has nothing to do with your problem.
Check the following: rag joint(between the steering column and the steering gear), steering gear, pitman arm, draglink, steering arm. You should only be able to move the steering wheel a little bit before feeling the gear and seeing the tires move. Make sure the steering gear is tight on the frame too. All of the above mentioned can contribute to your problem. Your tires aren't huge but sometimes larger tires require more dampening. i.e., dual or stiffer shocks or dual stabilizers. I don't know, maybe the others can help with that thought.
I jacked it up and found movement. It was a balljoint looking thingy at the end of the pitman arm and the drag link. When the tire turns it shifts side to side. Could this cause the wobble? What exactly is this part called?
Thanks
[ QUOTE ]
Thanks
[/ QUOTE ]
I would like to know the same thing /forums/images/graemlins/thinking.gif
[ QUOTE ]
would that cause it to wobble?
[/ QUOTE ]
As it moves back and forth it acts upon the steering box and then the steering box tries to conteract it and causes wobble.
