As usual, one thing leads to another. I have pretty much fixed the oil leak on the driver's side intake manifold which was the largest oil leak. I drove a bit more and have noticed another leak on the driver's side valve cover. Not much, but it's there. Unfortunately, to fix this means removing the factory AC compressor which weighs a good amount. I have a soft top so running the AC is not a real priority, plus I need to replace all the seals in the AC system anyways and recharge the system and from what I've read, I need to make some upgrades if I want the AC to effectively cool the Jimmy anyways. And I need to keep the AC bracket for the power steering. Currently running an original R12 compressor.
So what I'm thinking is lose the air conditioning and put onboard air or an onboard welder alternator setup. Not sure if I can convert my R12 compressor over to just an air compressor. Just wondering what my options are.
