Gotcha. I just remember there being 2 styles, one with short TREs on each end connected by a tube tie rod of which I had 2 of them (one original to the K5 and one from the donor 3/4 ton). And the other style was one long tie rod and one short one connected by the adjuster sleeve like in the above pic (which the parts places listed as 1 ton or 2nd design). And I thought the 2nd style was larger diameter but didn't have one to compare to and didn't want that style anyway cause of the adjuster sleeve. Anyways, I bought 2 new short TREs and the HD tie rod tube from ORD.
And x3 on using the other Dana knuckle. Had I known you had that in the parts bin I would have suggested that before. Simple solution and no need to buy anything.
