Opinionon this Welder Please...
Thats a nice welder..i would guess the box on top is a hi-freq unit used for welding aluminum & if thats what it is & its included, thats a good deal, ask if he has a aluminum spool gun that goes w/it if that is indeed a high frequency unit...if he has the alum spool gun(spool of aluminum is in the hand piece),thats a super deal!
That is just a external wire feeder. you can move that around rather than moving the entier machine, within the cables limits anyway. I work in a weld shop and we have them mounted on overhead booms so they can be pulled around the weld stall. As far as the quality of the machine hobart is a pretty good brand and it should weld anything up to haf inch and thicker with multiple passes. I hope that helps.
