badmix
what is consensus on bringing rear tires out to match the fronts?
People run the aluminum cheap ones all the time. You just have to religiously check them. But I wouldn't trust them. Steel, probably the safest wayOk , thanks, I'll forego them at this time, lol
I’ve never had any issues with spacers. 2-piece adapters? That’s a different story all together.People are timid, you always read horror stories with these things...
Appreciate that info.I have spacers on the rear of my 05 Silverado. Rancher I bought it from had put them on for exactly this reason, line the front and rear up so it goes through snow drifts and mud better. I didn't even notice when I bought it. 6 months later I got new tires and figured it out. 2 years later now and no issues. No loosening, no vibration, nothing wrong. Aluminum.
All sorts or reasons. Unfortunately Darwin isn’t right as often as he should be when they stack them and other dumb thingsThen with so many running these, why the horror stories, user error?
Plenty of videos and stories of wheels falling off on stock rigs too.Then with so many running these, why the horror stories, user error?
Same reason you get bad reviews on Google. They only talk about it when it's bad.Then with so many running these, why the horror stories, user error?
Did you use loctite on the spacer to hub bolts?I used these on the rear wheels of my suburban and couldn't be happier with them.
View attachment 421090View attachment 421091
