Orbitrol is in. New pics Feb. 23
Ronnie4wd
Stockholm.Sweden
Now I need to grind some on the 35-spline stubs so I can use the 8" stroke all the way.
Anyone else did this,any suggestions or how to do it :o
I am almost sure I read on here that someone had the same problem.
Did search did not find it please chime in :bow:
any pics of your orbital and mount? On my buddies 89 sub we put full hydro on it and it steered all the way to the stops on each side. Hes running yukon 35 spilines with CTMS, its also an 8" ram
pics are beeing taken along the build but are not on the net yet.
They will be up in a couple of days.
I have yukon stubs too but stock inners and joints maybe that is the difference.
Did he try to spin his wheels at full turn and no troubles:confused:
Here is some pics from last saturday
I hope you aren't warping the bore of the cylinder when you weld on it.
Mike
Mike
The welding was done before the cylinder was put together ;)
But thanks anyway :bow:
The cylinder was fabbed by a friend of mine and he welded the mounting plate on it.
That's good, I thought you were doing it after it was assembled.
Mike
There is a thread about full hydro on the street I am sure there is more info there.
My truck will see very little street though :wink1:
Protection:
And you have to try a little:
I hope that I can go wheeling next weekend bc it has been a long time now :crazy:
