ORD Draglink
scoots90245
1/16 ton status
El Segundo
Has anybody else used the ORD HD draglink sleeve?
I have the Moog 2026R and 2027L they are completely threaded in and the draglink is still 1/8" or so too long
The only fix i know of is crossover steering.
To actually answer your question it looks like you have the wrong ends. I ran into the same thing when i was restoring a 72 K10. The parts store gave me ends that were too long and i had to go back in to find the shorter option.
I used the Moog 2026R and 2027L but the ORD sleeve is 4 3/4" the old stock split style sleeve was 4 1/2"
This makes sense but i didnt want to cut rods or sleeve before asking
this was the old shorter sleeve i replaced
I ran the ORD sleeve with no issues with the ten bolt, and when I swapped in the Dana 60 I did have to tighten it up all the way to where there were no threads left on the drag link ends.
But like Wes said, chop off some threads, no problem
If the stock DLEs worked with the short sleeve, then they aren't touching each other inside the longer sleeve, and cutting won't help. You could cut the sleeve and/or source thinner jam nuts. That way, you're not modifying the wear item every time it gets replaced. Harder to clean up the female thread, of course, but should be do-able.
Is the new sleeve 4 3/4 or is that the sleeve + the jam nuts? I guess I'm surprised if ORD doesn't let the drag link fully collapse, because a too-long DL is a common issue for these (cutting the threads is common once the axle gets moved). They almost should offer 2 different lengths, as you can see how the jam nut design could end up with too little thread engagement for those running a long DL.
If you do cut the DLE threads, you can run the jam nut up it first, so after cutting, the nut cleans the end of the thread. Then file/grind a nice end on it and paint.
I didnt consider the jam nuts, they do add another inch between the two. I will take apart first then measure twice before cutting but i'm pretty sure thin jam nuts would do the trik
Thanks for the info
Thanks for the heads up, I cut 1/2" off sleeve and 1/2" off DL end worked out perfectly. The ORD Sleeve with Jam nuts are 5 3/4 and Sleeve alone 4 3/4"
It's weird how hard that is to find on their website: https://www.offroaddesign.com/dragl...length-threaded-7-8-18-r-l-with-jam-nuts.html
No description of how it compares to stock or what to do if the length is wrong. Possibly it's a liability issue to propose modifying the steering parts. You could contact @offroaddesign for advice.
I am surprised no one else has had an issue or mentioned it, My set up 3 1/2" lift drop pitman arm I can imagine every square has its own needs some shorter some longer I would offer a 4 1/2" sleeve and 3/8" Jam nuts if easy? Either way it feels great now and looks better than that split piece of foil:D
