ORD(u bolt kit) and GM(engine cross member)
Babaganoosh
1 ton status
Phoenix Arizona
Putting this out for a feeler, contemplating on going a completely different way on my project. I would like the leaf springs to go first before I start selling the rest.
1 factory 4wd cross member not cracked. $ 40
ORD U bolt kit. $35
I can include pictures if seriously interested. Most of this stuff is either new in the package or on my truck used as mock up. Let me know if you would like to negotiate on this. My loss your gain, these are seriously brand new parts used for mock up.
That stuff would look cool under my Blazer. But then I would have to buy tires. Then it would never end.
They are 4 inch stock length, stock center pin location. I think I had them do it for a little extra weight on the front end for the springs. Pretty sure I 650ish for them.
As far as the bilstein they are 14 inch travel have unibal bearings for the mounting locations.
The versatile 7100 Series shocks are designed for stock truck and limited buggy race applications as well as prerunner trucks, off-road and sandbuggies and other recreational vehicles. Completely owner rebuildable, Bilstein 7100 Series shocks come in remote reservoir or standard body with schrader valve fitments.
Self-Adjusting Deflecting DiscValving
2" Diameter Shock Body
High-Flow Piston Reduces Harshness
Choice of Valvings
Schrader Valve Shocks With Dividing Piston
Travel 14"
Extended Length 35.22"
Collapsed Length 20.83"
Any specific specifications you want?
I would buy the shocks tomorrow if you really ready to sell them.
If you decide to really sell, I would be interested in the ruff stuff U-bolt plates and ORD U-bolts / tall nuts and washers.
