ORD(u bolt kit) and GM(engine cross member)
Stephen recommended them with my 4 inch lift 12 inch travel springs. I don't remember then length or part number off them I will have to measure them.
Sure, I'll see what I can do. I have to remember where they are. :doah: Give me about 30 minutes and I should have it. They must be in the truck about 10 mins away, I can't seem to find them here with me.
Yes all 3 or the front's if you want.
I'll be headed over to the garage some point today, I'll take a look around for you and take them home.
ok. some measurements would help out. thanks
all 3 right?
Sorry it took so long, I couldn't find them to save my life.
GU30011
VEHICLE KIT (‘73-‘78.5 -- 4-6” lift) (2 fronts, 1 rear) $112.00
OLD #7215 FRONTS: 25” long, 3/16”IF @ frame, 7/16” banjo
REAR: 18” long, ¼”IF @ frame, 3/16” T-outs
Putting this out for a feeler, contemplating on going a completely different way on my project. I would like the leaf springs to go first before I start selling the rest.
1 factory 4wd cross member not cracked. $ 40
ORD Brake lines for 81+ $100
ORD U bolt kit. $35
I can include pictures if seriously interested. Most of this stuff is either new in the package or on my truck used as mock up. Let me know if you would like to negotiate on this. My loss your gain, these are seriously brand new parts used for mock up.
Thanks for getting the measurements to me. I'm a little unsure of something. Your original post says 81+, your build is an 82 but the brake line kit is for 70's? I figure you're using a 70s axle?
Ill have to give mine a check. Is it just the head size of 10mm or 7/16 they refer to or is there a thread difference?
I also noticed the Numbers don't really match up to ORDs site.
the 3001 is for 79-98 but then the "old7215"?? is 73-78. I am interested in getting those so this isn't just for zhits and giggles. Just trying to figure it out.
I went off the label on the package, I'm not sure. When I get home I will take a better look and try to solve this.
Ok It seems like ORD has the same part numbers for the different style fitting, these should be the 10mm banjo fitting.
Sorry for the confusion.
do you still have the cross member ? is it trans crossmemeber and what year im looking for a 1980 -84 4 wheel
