Parting NP241 ***SCRAPPED REMAINING PARTS***
pseudomike
MA
NP241, parts or whole. No reluctor ring or pickup otherwise complete with adapter for 700R4 or TH350.
Sorry about the delay...
If it did have the electronic speedo, I need the housing that you have removed (the one that houses the speed sensor and the rear bearing). how much shipped to 70583?
Yes, it was electric speedo. I robbed the sensor and reluctor to convert my NP205 that I installed behind a 4L80. The housing is in good shape. I don't know how much the thing is worth, how is $40 to your door for both pieces.
you take paypal?
How's $20 shipped to your door?
I don't have pics of the 205 during the process but I could go snap a shot of it installed under the truck. If you do a search on here for NP205 VSS you will find the thread I used as a guide to convert mine. I basically followed the directions except I used a lathe and milling machine. Mine came out essentially the same as the pics there except I have a slip yoke output...which I wouldn't recommend for a lifted K5 but this is a stock height long bed truck so I'm confident with the slip yoke. Also, I made mine with slightly more clearance, no issues with how it functions, and it doesn't appear to hit the reluctor either.
Sounds good do you take paypal?
