Parts cross reference.
BKinzey
Hollywierd, CA
What a pain!
Currently I'm looking for rotors for a 8 lug 3/4T 10 bolt front axle. The on line parts houses want to go by year, model, and VIN letter.
There has to be a better way for me to figure out which correct stock vehicle to use so I can find the parts I need than ask here every time.
How do you do this type of cross referencing?
Just lie to the computer. The rotors should all be the same from a 3/4 ton for any year solid axle with any vin code. It should not matter if it is a 70's D44 or 80's 10 bolt. My 10 bolt has rotors from a 70's D44 on it.
Harley
Here are the numbers from Autozone.
Hub & rotor: 55005
Rotor only: 5523
Chekcer numbers:
Rotor only: 5014RGS
Hub & rotor: 56287RGS
There are other options on the Checker website for more expensive rotors also.
Napa:
Rotor only: TS
4885677
Hub & rotor: UP
86286
There are more options on Napa's too.
Harley
BKinzey said:
What a pain!
you could have just asked me what the axle came out of ;) it came from a 90' burb.... but like hossbaby50 said any 3/4ton stuff will fit that axle....
