This thread is for the general discussion of the Item Patina Baja Buggy. Please add to the discussion here.
I'm going to resell the parts car as a roller without a motor but with the bus transmission. I just want the motor, shifter, gas tank, and cutting brake setup. It also has a title and only one rust spot under the battery.Nice, I've thought about building another one, mine was a mix of 69-72 parts with a Porsche 911 motor. Even with a baffle i could load it up and shoot a 3 foot fire ball lol.
? Are those similar to the boxed 930 arms or 3x3/4x4 arms?Did you get any 1x1 swing arms in all the parts cars you collected
I'm not sure what exactly is on the blue car yet, I pulled stock arms off the white car that I do not need.33 with the 3 rib should work out well. I have a 3 rib and 31's am tach'ing 3200-3400 at 65 mph 5.38 ring and pinion in those. You want to pass on the 68 and older 3 rib.
Did you get any 1x1 swing arms in all the parts cars you collected ? I might be interested if you did.
cause off road air cooled is cool
60+ is a lot!Nice build
I have owned more VW's then years I have been alive
yes same as 3x3 but shorter. Not sure about 930 arms I haven't done any research on 930 stuff other than cv's and axle shafts. I decided to use type 2 cv"s.
With 3x3 you would probably benefit from the 930 cv's greater angles.
