The body will stay a sedan.Are you chopping the top or keeping it a sedan ?
Is the engine from a bus or newer generation?This project lingered a bit too long at my friend's shop but the suspension is finally 95% complete. We tossed a type 2-1700cc in so I can try and get it through a state patrol inspection tomorrow. Then it will go into my shop to spray the lizard skin before the cage is built.
Type 2 is a bus, so yeah bus engine. Iirc this bug or donor had 3 x 3 trailing arms, these will move the tires 3" wider track, and add 3" to wheel base. Fender cuts and larger tires normally help with 3" extra wheel base.Is the engine from a bus or newer generation?
I have never seen the engine stick out that far.
Did you move the rear axle and transaxle backwards to clear the tire?
That makes sense now.Type 2 is a bus, so yeah bus engine. Iirc this bug or donor had 3 x 3 trailing arms, these will move the tires 3" wider track, and add 3" to wheel base. Fender cuts and larger tires normally help with 3" extra wheel base.
