Yeap 002 bus, type 2 all the the way.
The white car is a 1968 based on the serial number. I have rack and pinion with a 6" beam kingpin front suspension going on the white car. The blue car was also converted to rack and pinion but is ball joint.the type 2 joints are an easy upgrade and worth while if you have stock parts to use... have 2 friends that have been abusing some nice German ones for many years now. i assume the drive flanges on the trans are already type 2??
nice- you ever seen the aluminum adapters that bolt to the frame head and changes the tubing spacing- allows you to bolt a link pin beam to a ball joint frame head??The white car is a 1968 based on the serial number. I have rack and pinion with a 6" beam kingpin front suspension going on the white car. The blue car was also converted to rack and pinion but is ball joint.
A little over $7 per foot in this purchase, just shy of $1300 shooting there. More than needed for sure so I may start a cage on the M1028 with the left overs.That tubing doubled the value of that trailer.
For a car we will keep a long time and take to the dunes, the $400-500 difference isn't where I want to cut corners.How many cages you doing ?? DOM, is spendy spendy, wouldn't hrew be just as good, providing the design and welding are top notch ?
