PHOTO REQUEST: Fender "Pulls", "Stretches" & "Sections"...
Greg72
@MIGHTASWELLK5
Staff member
Super Moderator
Austin, TX
Not looking for post whoring of typical sawzall fender mod stuff here.... :whistle::D
I was curious to see examples of classic ways that hotrodders have modifed a stock fender to accomodate a larger tire when they are trying to preserve the "look" of the original vehicle.
Here are a few quick examples that I have photos for, though I don't know the correct industry term for each type.
Example 1: Fender lip cut, pushed out with extra section added to middle..
Example 2: What I call the "Pizza Slice" method:
Example 3: Not sure what you call this one....cut along style line of fender, pull down to increase amount of flare. Fill in gaps with strips of metal.
Obviously, Examples 1 & 2 are my own truck....just stuff I tried many years ago as experiments. The first one never had the right look, and I think it was just because I was making such a dramatic change in width over stock. The "Pizza slice" one ended up preserving the original shape perfectly, but it still needed some tweaking (actually to make it look a little less original) so that the aesthetics would be better.
Example 3 was just something I found from some Subaru WRX site. Mostly that technique is for fitting a WIDER tire under the fender, not necessarily fitting a larger diameter tire.
Anyway....we've got some "old school" hotrodders on these forums (Ryoken and Zim come immediately to mind!) so I have a feeling that in someone's personal photo archives there are examples of stuff that would let me do some good learnin' :woot:
Post 'em up if you've got them. And help me out with the correct "terminology" if you know what these different methods are actually called.
-G
I sectioned my wheel opening and moved it back 4" to make the tire centered in the wheel opening...still ain't looking to pretty but you can see the cut and weld sectioning going on here.
.....and just to clarify this does NOT have to be specifically on a Blazer / Suburban type vehicle.
I'm looking for ANY photos that show the process of opening up a factory fender to provide a larger opening. So I'll take pics of hotrods, musclecars, drag cars.... whatever you have hidden away in your PC "Photo Archive" folders. :deal:
-G
Also in my build thread:
With that said I have been contemplating cutting OUT my outer wheel wells and moving them up about 2-3".
Unless you are a hot rodder too, then you may be confused....pics to follow:
I started with the Driver's rear.
Taped area is what is going to be removed.
Metal strip removed.
Now I needed to make the two vertical cuts to remove the wheel well.
Inside Wheel well.
Here you can see the area where the wheel well meets the rocker after the wheel well has been moved up.
Here is the wheel well removed.
Wheel well inside.
In it's "FINAL" resting place.
Look MOM no Rockers!
The fronts should be easier, but that remains to be seen!!!!!!:D
here's some pages from the photobucket.. i don't know which ones you would want...
http://s184.photobucket.com/albums/x210/ryoken-ovd/#!cpZZ46QQtppZZ28
http://s184.photobucket.com/albums/x210/ryoken-ovd/#!cpZZ45QQtppZZ28
http://s184.photobucket.com/albums/x210/ryoken-ovd/#!cpZZ44QQtppZZ28
I'll see if I can hunt down some of the back later.... I didn't feel any need to do any sectioning up top... I'm only running 38's, so I really didn't think it would be an issue...
I have done some other jobs over the years... never gotten to do a roof yet tho...
54,
Good ones... I've admired those photos in your build thread previously. :waytogo:
Truth be told, I'm looking more for images that show how this is done on a curved fender (for obvious reasons! :wink1:) on a squared fender, the sectioning can be pretty srtaightforward, because the cuts get made areas where the fender lip is nice and linear.
If I try to do a tradional "section" job on a round fender lip, I'll end up with an awkward straight-ish transition in the area where the stretch happens. My pizza slice idea works, but it's a ton of work and welding/finishing. Im looking for other ideas that the pros use to make a small round shape into a larger round shape in a more elegant way than what I already tried.... :thinking:
-G
Only thing I've done is pulls and rolls with liberal baseball bat usage on lowered cars. Always wanted to do a nice metal flare on my 510
54,
-G
Thanks bud! Using the Pie method works good on round fenders, but you would have to increase the overall diameter of the opening, which may be your intent. I was just merely raising them, so it would work on ANY fender shape.
Lengthening can get tricky, but you just need to find the apex of the bend, cut, splice and weld.
I'm in it for the dirty pics!:haha:
Was actually just reading a thread on a guy who popped a older volvo body onto a lexus sc400 (1uzfe v8) chassis... and in his build he flared out the rear using all metal. Might be of interest.
http://www.pro-touring.com/showthread.php?73794-Got-Volvo
Now THAT was a good thread! :thumb:
I'm tempted to try his method of pulling out the fender, but I don't really need the tire coverage to solve my issues. The wire-frame model was a good way to try a few different profiles to see what might look good and to go through some quick revisions of the flare.
Ultimately, the use of that small diameter rod (~3/16") is a great way to create gentle curved shapes and to reinforce the sheetmetal once it starts getting full of "pizza slices". It's got me thinking now... :thinking:
-G
Wow! Nice one....
I like the large opening and the transition of the flare into the original fender. The only thing I'm not 100% sure about is the flatness of the front face of the lip. As viewed ffrom above, the stock fender lip has a slight curve as it runs front-to-back. From what I can tell that truck does not have that curve in it. I'll have to study the pics again on a larger computer screen to figure out how it was done.
Excellent craftsmanship for sure. Makes me feel like a total hack. :)
-G
