RckyMntnKng
- what material did you use for the cage?
- how'd you bend the tube/pipe?
- is it tied into the frame?
Thanks man - the short answer is its a modified version of a BroncoBob cage.
I took his standard K5 8-pt cage that he makes, and modified some dimensions to rake the rear hoop and make it taller etc.
Then I welded it together myself and bolted it down (Its shipped via pre-bent individual pieces of tube)
Its got 8 feet, each with four grade 8 bolts, and all the feet have plates on both sides that are offset in dimension to not sandwich through the body.
The bottom plates are then welded to the frame with kickers
