Pictures of DRW trucks, work’n trucks, etc…
I bet it’s to deal with the radio boxes or whatever they put in the beds of those. Big and packed full of heavy, tall stuff.
Because of the green paint ( or mildew ? ) on the frame rail can I assume that this is a M1028xx CUCV ?
Looks like it’s got the RPO G52 extra-extra high capacity ( GM’s description not mine ) 15K main 10 stack spring pack - plus the 11TH auxiliary helper !
Stoutest Square rear spring pack setup I’ve ever seen on the ‘73~’91’s.
More info on this truck please ?
I had a 80 k30 12k gvw trailer towing special all stock no mods . No sign of rear sway bar . . . Now 2wd yep seen a few with sway bar . Have a frame cut off now in my pile from a p3500hd 10 lug rear dana 70hd and sway bar all included .
Do you still have the spring saddle plate? I need one
Because of the green paint on the frame rail can I assume that this is a M1028xx CUCV ?
Looks like it’s got the RPO G52 extra-extra high capacity ( GM’s description not mine ) 15K main spring pack - plus the auxiliary helper !
You beat me to it.
The frame and the sway bar have green paint
You beat me to it.
I was look’n for mildew on the other parts and the rear axle housing appears to have a little mildew in spots.
I’d just like to know if it’s a double “G52 / C7E” equipped truck or any other info on it ?
Does it have a SPID ?
It’s moss or something similar. It wasn’t a military pickup. It was a crew cab. I just saw it on a Marketplace ad a few years ago and saved the pictures because I had never noticed a rear sway bar on a K30.
Wow !
Well, that may screw up the whole M1028A2 only sway bar theory…
It appears to have the “G52” spring pack that normally doesn’t come with the helper spring and the sway bar is a mind stumper for sure.
Did you get to see if it was a box delete crew cab ?
That was pictures that I saved from a Marketplace ad. From what I remember, it was a really rusty crew cab dually with a factory bed. It was also a couple years ago so I probably don’t remember very well. It seemed to be pretty original and the only reason I saved the pictures was because I had never noticed a K30 with a factory sway bar.
GM does have special RPO codes for specific non-standard equipment options - I wonder if this was a ordered commercial truck of some sort rather then just another run of the mill truck sitt’n on the dealers lot waiting to be sold.
No matter what that’s a very cool optioned truck and is most definitely certainly not standard equipment for a basic model # K30943 crew cab DRW K-30.
I guess the ole say’n is so very true “never say never”…
Good information !
They want $48k for it.
I'd almost trade them the burb. Lol
Found this truck on the Engineering Vintage website and got no idea of if this truck is original or not but it appears to be a DRW K-30 that originally came with a bed ( has the H.D. 70 w/ WMS 74” ) with a rear sway bar.
I thought these two pics were fitting for the Square era of DRW cool trucks - a first year offering ‘77 K-30 and a final year bringing a close to a fine run of super cool 1-Ton 4WD solid front axle Chevys ‘91 V-3500. It was a simpler time frame…
