Piecing together a full vert! (This Blows)
Well its been a few months, better update this again.
So I started focusing more on the body work before it got too humid out. Its not professional by any means but I think it turned out well! Next is to paint the white stripe the buff. I purchased some reproduction doors, biggest waste of money ever. The fit was terrible. Ended up looking forever on craigslist until I found a decent pair of doors from my year range. They are not the best but ill keep an eye out for better ones later on. In the process of looking for doors I found a complete original front clip that was in very good condition. I look forward to start working on getting it going under its own power. A lot to do before then though.
Oh I forgot to mention for painting I used 2 110v compressors hooked to a T fitting before the dryer/filter. It worked awesome! One compressor was a Craftsman 5.5 hp 30 gallon and the other was a Sanborn 6 hp 30 gallon that I borrowed. I painted a couple cars a few year back with a much larger 220 compressor and these worked just as well.
Looks awesome. What paints are you using? What color? Catalina blue? Which mirrors will you be using?
Thank you
It's eastwood coastal highway blue single stage and if I remember right the stripe is eastwood pure white single stage. The doors came with camper mirrors but i welded the mounting holes. going with chrome 3 bolt mirrors. I think they are called standard mirrors?
Like these:
Getting things done here and there. Lately I have been working on the engine harness. Just got the ecm back from being re flashed. Just need to finish wiring, hook everything up, fill fluids, and try to start her. I am hoping there will be no wire problems or fluid leaks anywhere but I should probably be realistic.
A little progress dump:
20170621_201429.jpg 20170622_184743.jpg 20170623_115038.jpg 20170630_162707.jpg WP_20170720_07_39_28_Pro__highres.jpg WP_20170728_08_03_48_Pro__highres.jpg WP_20170809_18_50_09_Pro__highres.jpg WP_20170809_18_50_09_Pro__highres.jpg WP_20170812_17_16_38_Pro.jpg WP_20170809_18_50_09_Pro.jpg WP_20171026_17_33_09_Pro.jpg WP_20171026_19_21_30_Pro.jpg WP_20171030_18_28_17_Pro.jpg WP_20171111_11_46_07_Pro.jpg WP_20171111_15_18_10_Pro.jpg WP_20170728_08_04_16_Pro__highres.jpg
