Went to the junkyard Saturday.
I got the correct crossmember!!
It took me a couple of hours, but it was worth it. I had to pull the d35 axle out first, then use the hoist to hold the engine up (this is also the engine crossmember), but otherwise it came out easy enough.
I decided it was easier just to cut the frame out, rather than try to get the crossmember cut away. Thank God for battery powered grinders!
Anyway, once I got it home, I removed my makeshift crossmember and installed this on the axle.
I was actually pretty close with my crossmember, but one thing I hadn't taken into account was where the were left to right.
The passenger side arm mounts almost in the center of the crossmember, while the drivers side is almost directly under the frame rail.
It took a fair amount to of effort to get this, but it's gonna pay off big time in less guesswork and wondering.
