**Please check my gear pattern** PATTERN #2
sunnyc123abc
SoCal
Can somebody please check my gear pattern. What should i adjust. thanks
Pattern #2
looks like the pattern needs to be moved a bit to the middle. dont forget baby steps. few thow is a lot. :wink1:
Pm readymix he can help.. but like everyone said I think you need to move more towards the center 1st one is two shallow, 2nd one is too deep. Did you reuse your bearings and crush sleeve, or did you get a new one?
It looks to me like your pinion depth is too shallow and your backlash is too large. How much backlash do you have at this setting? Did you set your pinion depth when you installed it?
Mike
You probably need about .010 less shim on the pinion and more backlash. Start by removing a shim from the pinion...then reset the BL to .006 -> .010
Feel free to PM if you need anything and I don't reply to your thread. I might forget to check it again
I could not see the other pics as I was at work. I get home and was wondering what was wrong with the pattern:doah: . I did not know he changed the pics out for the adjusted set. The ones up there look about where mine were on my 14FF when I put it together I say run it:D .
Ira
sandawgk5 said:
I dont think you should have red Xs in your pattern:D . Oh wait it is my work computer:doah: .
Damn NMCI not letting us have any fun.:o
Ira
you too huh :haha:
dayum websense!!!!!
