Silver84k5
I have a Fixed yoke Driveshaft, But the Shaft is from an Np208. which was bolted to the 700R
The thing is, I have 200$ to my name. And this is my DD. which I need to get on the road Asap
edit: Also I just found an Np 205 From a Ford? It's a Married TC I would be able to just swap my shafts into this If the Splines on the Case Aren't 27?
Ford has their front out put on the driver side, your Gm has it on the passenger side...
I have a th350 version 205 in my garage, too bad you werent closer. You should be able to find one down there, Before craigslist, there were junkyards... Try checking some out :P
