The Pumpkinator
Just to point something out; 14bolt full floaters are 1 ton 8 lug, and with 31" meats that pumpkin is gonna look massive, let alone you'll drag it on everything you drive over. There's also the fact you'll need to convert your front 10 bolt to 8 lugs (or carry two spare tires).
Why lock the front? I run a 10bolt/12bolt combo and both are open carriers, my truck does fantastic out on the rocks in Moab UT, sometimes a little bit of slip is a nice buffer preventing you from breaking drive train parts ( I detonated my rear limited slip 10 bolt with 33x12.50 BFGs by playing stupid doing a simple burnout on pavement
). Sure I will eventually swap in a D60/14 FF combo as most do, maybe install an ARB locker in the rear; that way if I need it all I have to do is flip a switch, but note that I pan on running 37" tires with steep gears.
If your going to stay with something around the size of 33s an open 12 bolt will do just fine, if you want to go any bigger that 35/36s then future proof your rig with a 14 bolt FF...personally if the 12 bolt is free AND has matching gears, why not?
). Sure I will eventually swap in a D60/14 FF combo as most do, maybe install an ARB locker in the rear; that way if I need it all I have to do is flip a switch, but note that I pan on running 37" tires with steep gears.If your going to stay with something around the size of 33s an open 12 bolt will do just fine, if you want to go any bigger that 35/36s then future proof your rig with a 14 bolt FF...personally if the 12 bolt is free AND has matching gears, why not?
Wheeling up here usually consists of tight trails through forest and typically wet and slippery ground and rocks. Open diffs usually don't get very far without a winch up here.
But I can still have fun on my 10 bolts till then lol. ty you a ton again. ps wheeling in New England needs lockers hehe I love it here
