4" and 35s has always been my go to for an on road truck. My tailgate is just right, dont have to hike your pants up to get in.
I’m 6’2” so height is no issue to me. My wife however is 5'2", so she would rather the truck be as low as possible.
When I did 3" and 33"s on my burb it rubbed. That was with 10" wheels and 3.75" BS though. Stock steelies would have cleared I'm sure.
I think the 10" wheels with 3.75" bs had more to do with hitting than the spring rate, but that probably didn't help lol. And after massaging the lower rear part of the wheel well lip with a rubber mallet it never hit there again.You also had a very soft spring rate. Other folks run 3" w/ 33s and do not have rubbing issues. Not that I think my springs are better than yours, I'm just pointing out that his results may be different than yours.
I like that setup a lot. The only thing I may do different is a 2.5" rear shackle flip instead of the blocks.I'm running 33's on 10 inch wheels. Zero rate blocks in front, and 2 " blocks in rear. 1" body lift, and stock springs. 3" lift shocks on all four corners, and longer brake lines. I also movedView attachment 359984 View attachment 359985 View attachment 359986 the axle forwards using the zero rate blocks. Rides very nice. Is very stable offroad, and will go almost anywhere. Some trimming was required at the front and rear of the front fenders. Most of this is caused by the 10" wide wheels, and also the wheel travel. Without the body lift, it would actually stuff the front tire into the top of the inner fender.
I agree. The rear blocks were a way of not dropping the fuel tank, and skid plate, to install the shackle flip. You won't have that problem with the pickup. I thought I'd try the blocks first, and if I got too much wheelhop, I'd swap for the shackle flip, but so far, not a problem.I like that setup a lot. The only thing I may do different is a 2.5" rear shackle flip instead of the blocks.
Are you running stock steering?I agree. The rear blocks were a way of not dropping the fuel tank, and skid plate, to install the shackle flip. You won't have that problem with the pickup. I thought I'd try the blocks first, and if I got too much wheelhop, I'd swap for the shackle flip, but so far, not a problem.
I am running stock steering. I can't do crossover steering without more lift. Moving the axle forwards worsened the short steering link problems. I've learned to drive it well enough, that it's not much of a problem. I've had my share of crappy steering box failures, and power steering pump problems, though. Putting on a NEW, not rebuilt box this weekend. We'll see how that works.Are you running stock steering?
Great information. Thanks for the help.I am running stock steering. I can't do crossover steering without more lift. Moving the axle forwards worsened the short steering link problems. I've learned to drive it well enough, that it's not much of a problem. I've had my share of crappy steering box failures, and power steering pump problems, though. Putting on a NEW, not rebuilt box this weekend. We'll see how that works.
With this much flex in the springs, I had to put a 2" drop pitman arm on it, otherwise it would bottom out the tie rod ends, and cut the rubber cups. lolView attachment 360012
