I say #1. Put a rear window in it with a wall. And turn the back into a pickup bed. Put pickup tailgate on.
Any reason why you wouldn`t use metal for the lower wall? I have a pickup cab wall I could get the metal from, Then I thought of cutting a piece of plywood the same shape and fastening it to the inside, for reinforcement.ryoken said:I would do the 1/2 cab the way it sits... you'll appreciate that interior room.. and backseats will take up more than you think.. i know it's at the wheelweels, but i would deal with that...
not crazy about the using the rear window, lower wall thing... get some smoked 1/4 or 5/16 lexan... and just slip in, or hinge at top.. you'd have to mod the lip for that... way easier than shortening the thing tho... i would do a fiberglass lower, in my case, I'd build out of composite, in your case glass over wood.. i wouldn't use metal.. and obviously the pickup tailgate..
the other option, for the summer is, if you make the lexan and lower removable, you could have a canvas guy make a full canvas backwall, that you could snap in, and have an upper isenglass window in it, for, $200, I'd bet...
I see. I think the reason I may not want to run it in the summer, is because I know that if I put the thing back on, I`ll most likely get lazy, and never take it offryoken said:Well, my thinking was, I certainly wouldn't want a permenent wall there.. I'd want something I could bracket and remove... run a removable wall and lexan thru the winter, then yank it all out and run a canvas gig the summer...
It'd be far easier to just do glass over wood... metal, your gonna be dealing with cuttin to fit, dealing with the body lines, attaching an inner (fastening is an issue. you'd really wanna bed it with an adhesive... cerrtainly not the best idea to run screws thru....
as i said, the old glass use doesn't appeal at all to me.. sounds like yu just wanna do it cuz of ease, and what you have... That glass is heavy.. sure you could probably screw right thru the track to secure it.. but it really wont be removable... and, it's potentially dangerous.. lexan man, it's the way to go...
i would just have canvas made to use with the 1/2 top.. pull out the wall/window, and snap it in.. straight up and down... if it was mine, i wouldn't consider taking 1/2 cab off often.. why bother? make the wall removable, and just run around open in the back when ya want...
Which probably isn`t a bad idea, and is more than likely the way I`ll end up going. I will still have about 3 ft of bedspace, 5ft if you I were to get a bed extender. It sounds better all ready.
I think its about time I believe in that.Tabb89k5 said:I say don't mess with a good thing. leave it as is.
