badmix
Like mentioned, replaced the Trans mount as well, they are super easy to do. I went with Poly on motor and trans, I get just a lil more vibration but nothing too bad. Everything felt more solid.
I blew out "anchor" brand engine mounts within 5 years, and I've probably got 30K miles on this thing in a decade. At the time I think "anchor" was supposed to be the top of the line aftermarket rubber mounts, or so the marketing claimed. Made in India as I recall.
Same problem with the 454 in a K20, although it had more miles. About the same time frame.
GM rubber mounts? Last 20+ years and 100K+ miles easily.
I paid 12 bucks for 2 "HD" mounts on rock auto and they look good. How long they last, still to be seen. Interesting. I found this thread as im about to replace a set of stock motor mounts with "HD" stock motor mounts from rock auto. I was all in on the poly motor mounts till I check the price on stock stuff. Ive been wheeling nearly 15 years and this is the first motor mount ive broke. Both mounts were less than 15 bucks shipped to my door. I figure at that rate, I need to break alot more to warrant 100 dollar poly mounts. Now if I break this set in the next year or 2 its going to be a whole new ball game.
Now back to what I was orginally saying before getting side tracked. Im putting these new rubber motor mounts in for my next trip. After that trip im intalling a doubler that already has poly mounts. From what your saying here I shouldnt run into any issues correct? The doubler has 2 polly mounts BTW, the adapter foot and the rear of the 205.
Part number 3.1116 inserts into the 4-bolt outer metal shell (4 bolts or rivets on each side). Part number 3.3121 inserts into the 3-bolt outer metal shell (3 bolts or rivets on each side).
