I should have said “do I need to send my injectors off for service?”.
The boat runs great.
Only issue I’ve had was it randomly and suddenly slowing to an idle when running on plane.
The code showed low drive lube but the reservoir was full. I think it was a stuck float switch.
yup, they get sludge in the bottom.. it's a common issue in spring commissioning ... the run issue sounds like it was fuel pressure related... do you have a spin-on between the tank and module? them freakin merc module filters are pricey...
, it screwed back in, but assuming that is a method of adjustment? I don’t have a scan tool get readings but could check the pins of the IAC connector. Assuming the valve itself needs replaced now, and it may have been working properly?
, actually had it stall it once coming off plane going to get a down skier. Going to pull the plugs and see if any differences.
