lectric80 said:Iif you could put say 50-60 amps to the system it should really speed up the windows.
no part number. They are just the standard universal bosch relay that any parts store should have.k204dr said:got a part# for the relays?
I think you have to have 2, If you go with one, it will power either wire ok, but the opposite wire will need to be grounded at the same time, Which wouyld require 2.wolfman said:If I'm not mistaken ( I just woke up) this relay is a change over relay. It would be possible to use a change over relay and get away with one relay instead of 2 I think.
I think this is a good idea because it keeps the switching logic of the door switches but removes the voltage drop of all those contacts. With the factory setup, the + and - are both going through two switches. I just wanted to comment that a good ground to the relays is just as important as having a good power connection. I don't really see either in the pic. If the power isn't run yet, then that little red wire is the ground?Terminal 85- power from the window switch.
Terminal 30- To window motor
Terminal 87A & 86- to Ground
Terminal 87- Goes to power, I used the junction block on the firewall, so I get as much voltage as possible.
I took the pic before I ran the power wire to them.
