Electrical:
The engine cranks over great when the distributor kill switch is turned off with the stock starter and with the high torque gear reduction stater. If the engine is cold, it will crank over great with the kill switch turned on or off. Once its fully up to temp and the thermostat is open, the engine will not crank over properly. Turns VERY slowly until it starts. If you flip the switch off, the cranking speed returns to normal. If its cranking super slow, and you just walk away from the vehicle for an hour and then try again it will crank over and start no problem. It appears to be pre-ignition when hot. The starter has a custom heat shield over it and the battery cables tested good. Its not a problem with the battery, cables, or starter. The kill switch and other tests confirm it.
As for installing a 160 thermostat, same reasoning. When its hot and the kill switch is not in use, it wont turn over very well. Let it cool down and it cranks great. So if its not the starter or electrical problem, then what?
I had a Nissan once that would start and run great. Once it got up to temp, the engine ran terrible and was hard to start. What was the problem? I have no idea, but after pulling the thermostat it started and ran great every time. No idea why, all I know is that it worked cold and not hot.
As for why my engine is getting per-ignition when hot? I have no idea, that's why I came here.
Installing the new distributor today, unless anyone has any other ideas.
Note: I am no expert, but I am a mechanic. I have two friends that are both retired mechanics (one was an engine builder). All three of us are stumped. We all agree that its pre-ignition when hot, for an unknown reason. All three of us have never seen a problem like this.
These videos were taken when the engine is hot. One time it starts fine with a knock or two. The other time it cranks super slow. .
