78 GMC Jimmy
sounds good to me. I'd say your about as flushed as you can get, w/o power flush. this was after chemical treatment and warm up ?
Keep an Eye on your heater core for a little bit, it may spring a leak depending on how old it is.
The full procedure went like this:
Flushed the entire system (and heater core) both directions with thermostat out using a garden hose (filtered water)
Installed 160 Thermostat
Filled system with filtered hose water and some Prestone radiator flush and cleaner.
Drove the vehicle at high RPM for around an hour, with multiple stops (running errands in town).
Total time with the cleaner in the system was 3 hours maybe.
Drained radiator
Sprayed off thermostat and radiator cap.
Blew air through heater core to flush hot water out of it to prevent shock from cold water.
Put a shop fan in the engine bay to motor to bring the temps down faster.
Hose flushed entire system and heater core both directions with hose.
Flushed entire system and heater core with distilled water.
Flushed overflow reservoir and siphoned empty.
Added concentrated antifreeze from one side of the system until I saw it coming out of the other side of the system (3 gallons).
Filled overflow to proper level with distilled.
Overflow jug, and heater core were just distilled water, plus I'm sure some distilled water remained in the block somewhere.
I guesstimate that this will result in maybe 70% antifreeze and 30% distilled water.
