andyblack
Registered Loser
35 spline shaft. Well nevermind then. It would probably cost me some money to find the right output shaft anyway. Thanks anyway.
Im going out on a limb here, but Im pretty sure the 465 can not handle the almost 500 ft lbs of input torque that 8.1 is going to shove down its throat. I could be wrong though.
Yep. I cant get my oil pan off my 454 now that its installed in the truck. And I have a cam and everything for it. The ORD bolt in crossmember might be a good idea down the road for you, as thats what I am going to do.
On your engine crossmember make sure you leave enough clearence, my motor settle and the pan is now rubbing
Had probably 1/4" on the back side.
Cut off wheels get old.Man, you really do some awesome work. Serious kudos.
The squirrels will never get close. I have 7 pecan trees in my yard and have gunned down over 100 of the bastards since I moved in last year. They steal my pecans.![]()
Not to bring up an old post but i saw this and laughed my ass off![]()
Seems like no matter how many of those things you kill, there's always more. I don't know if when you kill one, two more appear, or if they just come back to life as zombie squirrels and you keep having to shoot the same ones over and over again.![]()
So freakin jealous!!!!!!! They had two at the shop i learned to weld at. Loved both of em!![]()
I really thinned out the herd that first year. No one had been living here for a couple of years so they had learned to roam around with out a care. It wasn't uncommon for me to wake up and find 10 of them. I could normally pick off about five or six of them before they finally scattered. This year I have only killed 6 of them, as the only ones left alive go run and hide as soon as they hear the door knob turn.
I have this problem as well. I have resorted to opening the window quietly, and shooting them from inside of my house.....
Martin
I have the same problem. Damn things chew on my drip irrigation and make little geysers everywhere when they turn on. I got a beefy pellet gun thats pretty quiet and get them from and open window then wait 15-20 min between shots
