The engine swap creates some new questions in my wiring research. Apparently, the LE9 305 from the factory had an "electronic spark control" module. This was a closed-loop system that controlled detonation by modifying advance and then returning control to the "EST" or electronic spark timing distributor. EST distributors did not have vacuum advance. It worked from two sensors, a piezoelectric knock sensor on the passenger side of the block, (which is also present on this 350, curiously) and a vacuum switch on the firewall that provided a signal at throttle tip-in to retard timing to reduce knock - this vacuum switch is still left over on my firewall. Inside the cab, the ESC module itself was supposed to be mounted on the brake pedal bracket and it is gone. Someone bothered to hook up the knock sensor on this 350 and to hook up the harness to the vacuum switch, but not a vacuum line.
My '86 had an LE9 305ci, and did have the ESC/EST. It also had vacuum advance. From my understanding, the system exists only to retard ignition timing, not "advance" it to a pre-set physical limit.
My ESC module (and AFAIK all of them) is mounted behind the glovebox.
Now, here's where things get weird. According to the shop manual, only California rigs had an ECM and I did remove one from above the glove box in this rig. However, the original 305 engine VIN code (H) for this truck is wrong for a California (F) engine (yay CA emissions). Further, if you had an ECM, you didn't have vacuum advance, which really tells me nothing here since this is a swapped engine. The distributor on the 350 is a vacuum-advance HEI unit that does not have EST ("electronic spark timing", which would be signified by a 4-prong connector coming out of the distributor, with brown, black, white and green wire leads to connect to the ECM).
See above about the location of the ESC--exactly where the Cali trucks supposedly had an ECM. Furthermore, mine's not a Cali truck, but the closet wiring diagram I could find that matched was in fact, a Cali V6 truck...
So, how does a rig that does not have a California VIN have what appears to have been an ECM?
See above again, LOL...
I'm interested to see where this thread goes. I also had TCC. It was unfortunately eliminated during an engine fire.
I have some alternate method of lockup installed via a Tranny shop.Oh yeah... I swapped in a crate 350 as well, which I don't even know if it has a knock sensor. If so, it does nothing now. The ESC wiring was also toasted in the fire. Since I was no longer running a 305 and didn't need the knock protection, I hacked the HEI to make it function as an older unit would, with a single-wire hookup. I can provide the details of my FACTORY APPROVED HEI mod if you're interested (released in a service bulletin years ago). Apparently the ESC was known to take a dump. The solution was to eliminate it and physically retard base timing at the distributor.
Read post #35 for an even better description of the wiring of that particular HEI.
Looks awesome!
