Hey Guys - been lurking here a while and finally picked up my own square body a few weeks ago.
Introducing... GROOT!
This will serve as my project build thread and general question asking spot since I don't have much experience in the square body realm (used to be a Toyota guy
Anyways, I picked her up for a steal and have fixed the following so far:
Cracked exhaust manifold
Fresh seatbelts all the way around (old retractors didn't retract)
Upgraded stereo
Sway bar bushings
Drag link
New PS pump
New PSC steering gearbox since the old one was belching fluid all over the place
This has all worked out pretty well, but has made some of the other flaws more glaring. She likes to walk around alot while driving, which I'm guessing is probably worn ball joints and tie rod ends at this point. Also noticed this weekend though that the driver side spring plate is walking around all over the place, which is no good.
Here's a pic of the plate in question (yeah, I know I still need to pressure wash the crap out of this side. The old gearbox was really hemorrhaging) :
I'm worried that with the bolts loose and the plate walking around for who knows how long now that there might be damage to the center pin / spring pack. Anyone have any experience with this?
I'm at a spot where if it might be compromised then I'd rather just replace it with something well built so I hopefully only have to fix it once (reason I went with the PSC steering box).
Anyone see anything else I might be missing? She's got some aftermarket 4" lift (so says the PO) and I'm not impressed with the quality (ride or their install). Also, I pulled the dual steering stabilizer setup that was on there - both stabilizers were hanging up.
).Anyways, I picked her up for a steal and have fixed the following so far:
Upgraded stereo
Sway bar bushings
Drag link
New PS pump
I'm at a spot where if it might be compromised then I'd rather just replace it with something well built so I hopefully only have to fix it once (reason I went with the PSC steering box).Anyone see anything else I might be missing? She's got some aftermarket 4" lift (so says the PO) and I'm not impressed with the quality (ride or their install). Also, I pulled the dual steering stabilizer setup that was on there - both stabilizers were hanging up.
