pma4x4
AKA Yankeeroad
Before: 2012
After: 2014
The plan is to build a expedition rig that maintains its creature comforts, holds all that we need and can even be slept in on a regular basis if needed. Basically think of the amenity's you get with a small RV and that's what we are looking at doing to the Mule.
Third owner with paper trail back to original Arizona owner.
Stock Specs:
1991 V1500 4x4 Suburban
350 (5.7) TBI
700R4 Transmission
NP241C Transfer case
GM 10 bolt rear Limited slip 3.42s
GM 10 bolt front open 3.42s
32x11.50x15s BFG Ats a little weathered
Auto hubs
Goals: (D=Done, C= Cancelled, S=Shelved)
D - TBI upgrade
D - Tru-Cool LPD Tranny cooler with fan and thermal switch
D - 30K GVW inline transmission cooler
S - Sealed snorkel system using a Donaldson cyclonic air cleaner.
D - 3"" lift TC HD springs front
D - 3" lift in rear with HD 3/4" springs and 2" block
D - 4.56 gears
D - Manual hubs
D - 16x8 Wheels
D - Tires, 315-75-16
D - Dual AGM DC batteries (separate from the starter battery)
D - Front Winch bumper (Expedition XL)
D - Sliders/"Nerf bars"
D - Rear dual swing out bumper(11/19/18 Being re-worked)
D - Full length roof rack
D - Steering gearbox frame reinforcement plates
D - Steering brace from ORD
D - Power steering cooler
D - Custom Center console
Updates projects 12-4-2018
Check engine running temps (seems cold, could be sending unit (Bad info to ECM cause bad MPG)
Ford Windstar fan upgrade
two temperature controlled fan circuits for Windstar fans.
12v 3 wire heated O2 sensor
Front door power window relay upgrade
Front door power window motor replacement
Front shock replacemant
Adding dual inline steering stabilizer.
Add fresh coat of coo top to roof
Repaint truck to grey with black accents
Get roof rack powder coated
re-design control center in center console
Add Emergency LED amber and white LED strobes (for Skywarn "Weather chasing)
Undercoat the entire bottom side (pre Minnesota move)
Powerplant upgrade (maybe before end of 2019)
EQ Vortec heads (55-87 bolt pattern)
Edelbrock Pro-Flo 4 EFI system
Headers
Camshaft & Lifters
Timing chain
QUICK LINKS IN THIS THREAD
Muffler and Cat swap out
Starter battery swap out
Items planned for custom center console
Front winch bumper for production begins
Front winch bumper (2)
HD transmission cooler, PS cooler and temp-controlled fan install
Rear bumper v1 (1) (scrapped)
Rear bumper v1 (2) (scrapped)
Rear bumper v1 (3) (scrapped)
Axle tear down (1)
Roof rack build
Hood louver cooling mod
Painting the burb
Roof rack mounting
Front Winch Bumper Build (3)
#487 Roof Rack (2)
#509 Dual battery tray build
#553 Dual battery tray wiring
#584 Sliders (1)
#605 Emergency battery welding kit
#618 Roof Rack (3)
#655 Sliders (2)
#670 Rear bumper v2 (1)
#687 Sliders (3)
#744 Rear bumper v2 (2)
#756 Onboard battery charger and more wiring
#771 Suspension lift and new axles go in (1)
#793 Steering box frame reinforcement plate kit
#807 Suspension lift and new axles go in (2)
#826 Steering shaft upgrade (eliminates rag joint)
#829 Extended brake lines using factory lines
#849 Suspension lift and new axles go in (3)
#865 Final results (at the time) list of work and images
#878 DRAC mod adding dip switches to recalculate speedo
#971 Tune Port Injection Torque monster plans (cancelled)
#1002 Center console build (1)
#1009 Stereo system upgrade
#1020 Gauge cluster LED upgrade
#1030 LED part # list for entire truck
#1057 Center console wiring
#1154 11-19-2018 - The rebirth
#1180 Steering column rebuild
#1182 Ford Windstar fan upgrade
OTHER THREADS
1991 5.7L Bored TBI Upgrade Write-up (warning LOTS of pics!)
'89-'91 Suburban LMC Headlight and Wiring Upgrade Write Up with Pics
ALDL Droid OBD-1 Bluetooth Adapter review
Cool Coat Rooftop coating Write-Up
Another Roof Rack thread for a Suburban
1/2 ton Auto Hubs to Lock Outs Swap Write-up
After: 2014
Stock Specs:
350 (5.7) TBI
700R4 Transmission
Auto hubs
D - TBI upgrade
D - 4.56 gears
D - Manual hubs
D - 16x8 Wheels
Headers
Camshaft & Lifters
Timing chain
Axle tear down (1)
Roof rack build
Painting the burb
Roof rack mounting
#487 Roof Rack (2)
#584 Sliders (1)
#618 Roof Rack (3)
#655 Sliders (2)
#687 Sliders (3)
OTHER THREADS
