The NV4500 is now in a local K5, sorry dude!
The glow plug code went away all on it's own after a while. It was P0380, general glow plug failure code. The low coolant light came back, I haven't put the time in to fix it yet.
That said, I have some work to do on my truck... I hit a wash going around 50mph or so and friggin deeeestroyed my front diff
Carnage included a grenaded set of wheel bearings and locking hub, which damaged the wheel hub, which damaged the chromoly stub shaft, which damaged the brake rotor, which damaged the bracket and ground the caliper bolts up, haha!
Oh, and I also broke the plug welds for the long side axle tube and bent / broke one of my sway bar links
So, I think I am going to wind up ordering a high clearance ProRock 60 from Dynatrac for it. Cost is just a little over 2k for a high clearance housing, axle tubes, Reid inner Cs and a HD diff cover. My existing gears, locker, axle shafts and knuckles / spindles etc will all bolt straight in and onto the new housing. I'll also build a truss and convert the truck into a 3 link coil over up front. I should then be able to drive fast without destroying my truck
