Project Penny - All good things must come to an end
I'd been aiming for closer to 60% and I think I will tweak it a bit yet to get it there. I like having the front end dive a bit under braking, but at the same time I don't want the front end to lift any when I am trying to hill climb. I'd rather have the front stick down and loose some of the dive vs having to use a suck down winch to keep the front end from unloading on a hill climb.
Neither of your designs has enough negative roll axis (IMHO)... That second one looks downright dangerous for street driving (2.5* of roll oversteer! :yikes:)
-G
So, what kind of a target roll axis angle should I be targeting? I understand negative is good, but how many degrees negative?
I disagree, my truck has several degrees of roll oversteer and I drive it on the street all the time one handed, it handles perfectly fine because my steering is in good condition and I have plenty of caster.
I'm the odd one here, but I think everyone over reacts and says to shoot for negative because it has evolved in to what it wasn't supposed to. Yes, understeer is better than oversteer, negative is better than positive. If you have to err on one side, err on the side of understeer if possible, it can work well.
However, since when do we want our trucks to steer us when we hit bumps? Ideally it would go perfectly straight when we hit uneven bumps. I know when you start a turn the body lean has an effect. So if you start a turn and then it leans over and turns more, that is less desirable than if you start a turn and it leans over and turns less.
I still say shoot for zero, and if you get some negative thats fine. But to be honest, I think caster is more important. If your caster is wrong, your roll steer can magnify the issues which caster causes.
1.9 should be fine you just need some. But too much is almost as bad.
It defines whether your front axle steers into the turn or fights the turn. If your number is positive it will fight the turn if its negative it will steer into it.
I agree, too much is just as bad. However, I think you are backwards on the negative/positive thing.
Anti-dive only works when you are on the brakes. When climbing a hill in 4WD it won't have the same effect, and if it does, it will be opposite, it wil want to dive under power, which counteracts the raising nose and has little effect.
The reason is because the direction the axle housing is torqued determines how it reacts against the links. When applying the brakes it torques the axle housing and tries to raise the vehicle, under acceleration it torques the axle housing the opposite direction and tries to lower the vehicle.
This is backwards from the rear suspension which is called anti-squat. Antisquat tries to raise the vehicle under acceleration, and lower it under braking.
However, when applied backwards (antidive under acceleration and antisquat under braking), they have little effect because of weight transfer, leverage, and traction.
Russel likes to go fast and hit things hard as evidenced by him breaking a 60 in half.
I think that he will go to a dynatrac or some such housings on this one too.
What Heath said is true if your suspension numbers are brilliant and other things are worn out too much it won't matter one bit. If everything is top notch then it will all work better.
I think I can distill most of his post down to a sentence. Don't get too hung up on the numbers!!!!
Especially one single number. Look at the truck as a system. You build stuff different if you are keeping rear leaf springs. I prefer a much higher AS number if you are keeping leaf springs in the back. But that is mostly experience with much lighter trucks than yours Russel. Being that your heavy engine is over that front axle I think getting your spring rates right will be more important than the overall AS numbers. In addition when coming down a rock face that is stupid steep and hitting the brakes I prefer the nose to stay where its at. So I like higher AS numbers.
I have said it before its very very hard to get the numbers exactly where you want them for a front suspension, just a fact of life. The whole front suspension is a compromise and you do the best you can with what you have.
So, I've been thinking about what I actually want to do with this truck, and I am thinking I may keep it leaf sprung and put a stock 78/79 D60 back in up front. I'd swap the guts from my current diff over, along with the aftermarket knuckles, but I am going to keep the stock inner Cs to restore my steering angles.
However, that does mean that while Penny is going to stay a "mild" trail and chase truck, I do need to start building Penny's evil twin ;)
This is what I am considering purchasing. High miles, blown engine, worn out suspension but a solid tub... Seems like a great candidate for a Vortec 8100 / Allison 5 speed / NP261. Fabricated housings front / rear, full coil over / link suspension with bypasses. Roof chopped off, interior gutted, fully caged, race seats, harnesses, no glass, narrowed front / rear rolling on 40x16x17 LTBs. I want this truck to fly, bog, bash trees and generally fullfill the role that my old Jimmy used to. I want to compete again, and I want a truck that I don't mind rolling, running into stuff, jumping and going really fast in.
build a buggy.
No not kidding. I understand the need for being enclosed up in your area, but thats not an impossible thing to do in a buggy just takes some planning, even some type of fenders could be arranged as to make it easier to keep some of the mud off ya. But if you are going with no glass in a tahoe then you aren't that worried about weather tight it sounds like.
I realize it would probably take longer, but you are gonna be doing tons of mods to the frame more than likely to get everything just right. Better to do a 4 link up front I assume it will be a full hydro steer type of truck.
I just think, no wait, I know you make a ton of compromises when you build a truck based buggy. It weighs more than it should, is too wide, too much metal everywhere. It gets ya real close but if you are gonna spend a ton of money on parts and stuff and use all high quality stuff building a scratch built rig would put you on a way more capable plain.
Just my 2 cents.
I think Penny is a super cool ride but I still think you should do coil overs to her too :D:D:D
How about Cecil, or Nigel, or Florence maybe...those are all real tough names. :dunno:
Is that the one you need the OOP on Russ?
Finally got a break in the winter weather and enjoyed some sunshine with above freezing temperatures today! So, I jacked the hoe up and ripped the front end out of it. I am sending it down to Evolution Fab and Machine to get them to properly repair my broken axle tube welds as well as install a balanced ram steering setup to replace my current high steer / hydro assist system. Basically the ram will center mounted and will have two short tie rods that run out to the knuckles. I am still going to be running a drag link for a mechanical steering link as I do regularly drive my Tahoe on the street.
I have decided that while I am going to 3-link my truck yet, I am just going to keep the leaf springs up front for this wheeling season. Should be a good winter project instead. I'd rather fix a few other glaring issues first (like the steering and rear suspension).
So no ProRock 60?
Nope. After getting some quotations I decided that I am better off to just fix the housing I have, esspecially if I am sticking with the leaf springs for right now. My existing diff is pretty modified and it was going to cost a lot of money to make the ProRock match. I had the spring perch on the center section shaved down and a wedge welded in to tip the pinion angle up, then new the outers welded on for proper castor. The outers are solid axle industries stuff.
With the housing properly welded and a small truss to support the long side tube I think it'll be good to go. Esspecially if I stop driving it like an Ultra4 top racer :haha:
