Project "piss Adam off by Cutting Good sheetmetal"
Got my paint stripping wheels from Roark supply. Going to be picking up some steel this week to brace the tub then it's sawzall time :). The primer I ordered should be in on Tuesday.
Done reading Ryokens guide. This will not be a show truck by any means but it will have a decent paint job on it. Going with House of Kolors Cobalt blue
Did the old rig with a HF spray gun and it turned out okay. It was a single stage job though.
Anyways I went to my dads picked up the somewhat rolling chasis. With come clever ratchet strapping I was able to lock down the rear axle and get her up and onto the trailer. The frame is in worse shape than I thought though. Going to start blasting and stripping the frame and see how bad it is. The problem spot is the middle of the frame under the body mounts. I could repair it but I fear if there is one spot, there is probably going to be more. Kinda bummed about the frame but I guess Its only metal and I have a welder.
Anyways pics
First one is the field at my old mans
Second is at my house
Third is what is left of the old k5
What year front end sheet metal are you going with?
The core support is from a 89. I would like to go with an an early 80's front though. The 89 front clip is overrated. I want to keep it simple with sealed beams etc. I really liked the front of my 83
HOK, has some real nice products to work with, (expensive too)
I painted my bike with their Kandy Tangerine and Orion Silver, and its prob the best paint I've sprayed with....
