So the saga continues......................
Hooking up the parking brakes for a 99-04 Silverado rear axle to a 88 Suburban.
Using the complete rear axle including parking brakes from a 99-04 Silverado (others may also work). Make sure to get the frame bracket and the cable combiner.
You'll need a Lokar "single wire union connector" about $15 and the bracket from the Silverado.
First is the adaptor:
Here is the Silverado bracket installed on my 88 Suburban:
I did not get it exactly vertical but it's close enough.
The Silverado cables ran through the stock burb bracket, I did have to open up one of the holes with a step drill to get them to fit nicely:
Here is the stock cable and the Silverado cables zip tied to get the cut length right:
And the parking cable end installed and adjusted right:
You can see the left over part of the stock cable guide I removed in the bracket picture, it was just in the way of the new cable arrangement. And was unnecessary with the new Silverado bracket supporting the cable ends. The new arrangement almost exactly follows the stock line placement, right along the bottom of the frame. With the side steps I'm adding the cables will be protected nicely. If you don't scrape your frame on rocks you'd be fine with the stock location. It is no more in the way or drags any worse than a stock chevy parking brake would.
ETA: forgot to add, I stripped the cable cover from the stock cable so the set screws would have a solid steel to tighten against. I did leave a little inside the adaptor to help keep it clean. I also used red locktite on the set screws and cable end, red on the threaded rod into the adaptor, and then blue on the threaded rod/adjuster nut.
