correct - 10% blend
Where it is now
Back in Oct last year
post #30 I did the evaporation calc and in
post #53 I got a good data log of fuel temps over time - with a 120 deg F fuel bowl, after shutdown in the first 2 hours a quarter of the fuel should evaporate (
measured in post #95) and then over the next 24 hours another quarter evaporates. Checking with the gauge, after three days the fuel float was basically bottomed out (
post #118). My fuel temps are now lower than what I estimated back in post #30 - that calc was what convinced me to try and lower my fuel bowl temp. I can let the truck sit for maybe a day longer than before without trouble starting. Blazer74 had the solution here in
post #69 (posts #66 through #71 are on ethanol).
Here in
post #141 I confess that it is just a challenge to get the mechanical pump and q-jet to work w E10 fuel.
At this point, I think I have verified the q-jet fuel bowl is too small for E10 fuel for fast starting if the vehicle is not started every three days. Back in
post #1, the technical report I posted by the q-jet designers, said the fuel bowl was just barely adequate to accommodate 1965 fuel evaporation after shutdown so it should be expected that E10 fuel will evaporate. Placing the fuel bowl between the bores, the need to limit carb height to accommodate low hood lines, and sufficient fuel to start after evaporation became a major design problem for those guys. What I'd like to know is why they did not use a check valve on both the accelerator pump inlet and outlet to make the pump shot captive (
post #216) - the fuel would probably stay in the plunger for months.
After the final on-the-fly tune in
post #209 everything runs good, no low end bucking, starts right up hot or cold (assuming it has ran in the previous couple days and accel pump has fuel), and the 13mpg fuel economy is acceptable (
post #207). At this point I have duplicated exactly what blazer74 relates as his experience in
post #169 I think it is what it is with E10, mech pump, and no return lines (never have nailed down by how much return lines would reduce fuel temp - though it is clear this is what the return line is for - said best by dyeager in
post #175).
Final issues
The last issues to resolve are my electric choke, the fuel pressure gauge, and checking the A/F on wideband:
I bought an electric choke that had more heat coils in the picture but they shipped me the cheap version,
post #205. I will buy from some different vendors and see if I can get one. Alternative is return to the heat pipe - my coil for the heat pipe has a bunch of coils.
Check the fuel temp with the insulating sleeve, the radiant heat sleeve, and with no sleeve. Maybe I will buy a steel fuel line and check fuel temp for steel line versus rubber line.
Anyone know why the fuel pressure drops as the temperature rises (
post #215)? I will search online too. Answer my own question -->
"The glycerin used to fill the gauge heats up and expands, and being inside a sealed container (the gauge case), the internal case pressure rises. Internal gauge case pressure can increase as much as 1-9 PSI above atmospheric pressure when hot. For every 1-PSI of pressure rise inside the case, the needle will fall 1-PSI." aeromotiveinc.com
Sounds like with 8psi cold a fuel pressure regulator is in my near future - that could change the fuel economy.
The wideband is still on the back of my mind. Probably first I will take it to the shop - they all have dinos for the smog check, we can check the tailpipe A/F.
Where to next
Timing
Next, once the choke starts working like it should, I want to go back to sreidmx's recommendation to understand how my timing advance works and tune that. I confess - the advance curve is a huge mystery to me. I will start a new thread for timing and go at it.
Cooling
Also a new cooling setup is in the future (
post #211) - the OEM '74 radiator was marginal when new. I'd like to use a dual electric fan and a redesigned radiator. What I have now works 98% of the time (cant beat a flex fan for simplicity) and even in the 2% of the time things are not nice it gets me by with some attention - so it is difficult to justify spending time on the cooling.
