From my experience you don't want pressure maintained in the lines between the pump and carb.
Hot start problems can be created by pressure build up in the lines due to heat.
After hot shutdown pressure builds and overcomes needle and seat causing flooding requiring pedal to the floor for start after about 15 minutes. I had this issue.
I have the holly reg in my closet, yet to be installed would remedy the pressure build up I would think.
I had this problem with my stock pump, remedied by a EDL pump , 5-6 psi and drops off pressure within a few minutes of shutdown.
Be cautious of over the counter pumps. Many put out to much pressure, as much as 9 psi and cause flooding issues.
